i need these parts asap
i need the whole clutch set up i have the pedal assembly i need everything from what connects to the pedal to the through out bearing.
Aurelio Landeros
1970 f100 240 I6 3.9L 1bl carb 4 speed light duty
- CH3NO2
Re: i need these parts asap
I think I have what you need.What motor & trans do you have ?
[quote="CH3NO2"]I think I have what you need.What motor & trans do you have ?[/quote i have a 240 i6 with the three speed light duty i also need the power steering brackets and the accelerator cable
Aurelio Landeros
i also need bolts to hold down driveshaft to frame
Aurelio Landeros
