Not mine....
About 80 miles from me.
http://winstonsalem.craigslist.org/pts/4985568388.html
I have a 3speed transmission out of a 68 f100 that had a 360fe motor. This truck is a 1 owner pickup and been in the family since new, it has 49,000 ORIGINAL miles. This transmission is not seized up just needs new clutch as expected after sitting 13 years. Was drove everyday in working order till then. It has the automatic overdrive which was a lever that you pulled inside and it would shift into over drive on its on.
It is called a Warner T-85N 3-Speed OD.
I am asking 300 or best offer.
Call or text show contact info
Thanks
3speed transmission with overdrive
- wndsofchng06
