OD for a 460
OD for a 460
Some parts of Hot Rodding never change, but I've been away long enough for the alphabet soup of trannys to have moved on without me. I have a 69 bump that is getting a 79 460. It currently has a C6 attached. As I approach the "mock up" stages I would like to include the final transmission. (Just saves plowing the same ground twice) What is the current wisdom on ODs for 460s? I prefer something non-electronic or, at least, self contained. I'm an analog kind of guy and a bit of a luddite.
Greg B.
Greg B.
When the woman screeched, "Alcohol, Tobacco and Firearms!" I, naturally assumed it was a delivery....
"We have given you a republic, madam, if you can keep it!" B. Franklin
- HIO Silver
Re: OD for a 460
Welcome to Fordification...
With a 460, I'd be looking at Gear Vendors Overdrive (GVO). https://www.gearvendors.com/
https://www.gearvendors.com/f2wd3s.html
Re: OD for a 460
HIO Silver; Thanks for the response, but I have to find something that I can get at an auto recycler (Didn't they used to be junk yards?
Greg B.
![Hmmm :hmm:](./images/smilies/icon_hm.gif)
Greg B.
- HIO Silver
Re: OD for a 460
Ah.. Then it'll be an AODE or a 4R70W.... plus a controller.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
Re: OD for a 460
I'm getting older, so I have to get out more.... I have yet to see an AODE bolted to a big block. 4R70W, hmmm. Research is in order.
Thanks,
Greg B.
Thanks,
Greg B.
Re: OD for a 460
E4OD will bolt up to a big block, the AOD won't...there are adapter plates out there though.
69 F100 - Coyote - Gen II Flavor
Re: OD for a 460
Research a Ford E4OD transmission. It should be a direct bolt up to a 385-series 460 block. A 4R100 MAY bolt up. It's also possible to use some of the stronger internals of the 4R100 in the E4OD.
Steve
Re: OD for a 460
Thanks, gang.
A little more research, but it's almost as much fun as block sanding.
Greg B.
![FORDification Rocks! :fr:](./images/smilies/icon_FORDification.gif)
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Greg B.
- ToughOldFord
Re: OD for a 460
There is an E4OD that will bolt to the 460, but it is a pile a crap, hence the nickname E4DOA
If you're not stuck on an automatic then just go with a ZF 5-speed.
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
Re: OD for a 460
Earlier versions perhaps, however E4/4R's that stand up to big diesel torque are built and driven everday. Simple valve body changes make a significant change.ToughOldFord wrote:There is an E4OD that will bolt to the 460, but it is a pile a crap, hence the nickname E4DOA
- derbydad276
- HIO Silver
Re: OD for a 460
Specify and bolt-in a short-shaft Tremec TKO 5-speed from Modern Driveline.
![Image](http://i44.tinypic.com/eg8kms.jpg)
![Image](http://i42.tinypic.com/2edqjb6.jpg)
