don't know where else to ask about this
erikd428
Post by erikd428 »
Hi ya'll
Been a while since I have been on here. But I have been looking around a little at the builds you guys have going on, and was wondering in particular if anyone has info on doing a bumpside cab and bed swap on to the next gen chassis (80-96).
I have 2 decent candidates in mind to make it happen. but they aren't currently right in front of me to visually inspect them, and won't be for a while. So I thought I'd ask since I couldn't find, if anyone has an example of this swap. thanks for your help
71 SWB / 2wd 302 Auto 3.70 posi
70 Boss 302 / close ratio 4speed 3.91 Posi
erikd428
Re: don't know where else to ask about this
Post by erikd428 »
sorry, right details
2wd, half ton, long wheel base layout.
fordguy_78
Post by fordguy_78 »
I know its not a 2wd but it had twin traction beam and those will interchange between the 2. and the truck chassis may be easier due to having rear cab mounts already and rear frame rails don't hump up as much but the front cab mounts bolted right in. You may just have to be the first.
and if any one notices i did go reshim my bed after looking at this pic
Also here is a slick sitting on an 80's bronco frame.
Phill
78 Mustang
67 F250ish
2010 F250 Harley Davidson
erikd428
Post by erikd428 »
interesting. thanks for posting.
