New parts added 1967-1972 F100/F250 parts galour!!!
Private parties only. No eBay/Craigslist listings.
jp2005
Post by jp2005 »
Cleaning out my garage and have some good healthy 1967-1972 Ford truck AZ parts.
1969 grill $150 good shape, one dent, straight
Heavy duty 2" hitch $110
Painted Radiator support $60
Heavy duty bumper $100
Aux fuel tank skid plate $40
1972 F100 complete, Shortbed trim very straight,minimum dings,black is faded. $80
A/C blower unit $60
Ranger emblems $15 each
70-72 F.O.R.D emblems $20
Hood side emblem $20
Taillight bezels ok set $10
F250 Hub caps set $30
72 grill insert $30
Sport custom emblem $25
C6 transmission pan $20, needs cleaned
Older ford A/C compressor $30
I can send pictures.
nxne75
Re: 1967-1972 F100/F250 parts galour!!!
Post by nxne75 »
Interested in the '69 grille - can you post pics? Thanks.
mjd69f1
Post by mjd69f1 »
Interested in the radiator support, will it fit a 69 ranger with a 390? also will you ship to NY? id like a pic or two if possible.
Thanks!
Mike
jp2005
Post by jp2005 »
Pm sent
Devin Ezersky
Post by Devin Ezersky »
What do the F250 hub caps look like? Can you post a picture please?
Mine is bent.
jp2005
Post by jp2005 »
Pictures can be seen here http://phoenix.craigslist.org/nph/pts/4540607995.html
Grill to hood latch body $50
A/C blower unit $60
Battery tray $25
Tail gate supports set $40
Tail gate handle $50
Tailgate side supports hinge $20
70-72 turn signal support set $40
Rear LH reflector $10
One f250, Hood side emblem $20
Taillight bezels dents set $5
72 grill insert $30
2x Factory 390 crank pulley $40
2x Factory 390 water pump pulley $20
Factory Ford power steering pulley $30
jp2005
Post by jp2005 »
Devin Ezersky wrote:What do the F250 hub caps look like? Can you post a picture please?
Mine is bent.
BLS2042
Re: New parts added 1967-1972 F100/F250 parts galour!!!
Post by BLS2042 »
Hi
I am interested in the aux tank skid plate.
What does it include , hardware, brackets
thanks
elsilerjr
Post by elsilerjr »
Thanks for the hood letters JP
jp2005
Post by jp2005 »
elsilerjr wrote:Thanks for the hood letters JP
[ Image ]
They look good! And your welcome :thup:
jp2005
Post by jp2005 »
BLS2042 wrote:Hi
thanks
I have the brackets but I would buy new hardware.
jp2005
Post by jp2005 »
Mine is bent.
Still interested?
natec96
Post by natec96 »
Do you still have the AC blower and compressor available still? Also do you know if they're in working order? Thanks. Nate
jp2005
Post by jp2005 »
natec96 wrote:Do you still have the AC blower and compressor available still? Also do you know if they're in working order? Thanks. Nate
Pm sent
jp2005
Post by jp2005 »
Hey guys still have tons of parts available.let me know
Pictures can be seen here.
http://phoenix.craigslist.org/nph/pts/4606727112.html
1969 grill good shape, one dent, straight sold
Grill to hood latch body $40
Heavy duty radiator $20 needs fixed
Tail gate handle $40
70-72 turn signal support set $30
Ranger emblem $15
72 grill insert $30
Older style Ford Ac compressor $30
Factory 360/390 Ford cam $40
390 truck oil pan, needs drain plug fixed $5
2 sets of door step plates $30 each set
1 set of wheel we'll trim $30
3 Rim caps $20
360-390 intake set $25
Door steps $30
Window washer reservoir $20
