Misc FE parts
Private parties only. No eBay/Craigslist listings.
habu
Misc FE parts
Post by habu »
Now that my engine build is coming to a close I have some extra parts that I will no longer need. All of these parts, new or used, have been sitting in my garage or about 1-1/2 to 2 years waiting for me to build the motor and get the truck back running. There is never enough room in my garage now that there is a chance to get rid of some of the stuff I'm doing it sooner rather than later.
Shipping would be from 90245. If you are in SoCal we can meet somewhere and eliminate shipping if you would like. I do take paypal and will ship after payment is received.
*new* Precision Oil Pumps, oil galley plugs and restrictors for the head.
$15
http://stores.precisionoilpumps.com/for ... -lr-heads/
*new*, but old. Edlebrock roller timing chain del-7808. This set is new, but it's old. Has some light, wipable with a rag, rust. Some assembly lube on it still as well as some oil.
Had this but it would not work with my motor, which was line-bored. For a straight replacement it should work. My engine guy was going to use this but because of the line-bore on my block we went with another chain set
$40
Starter and Balancer are SOLD
*used* oil drip tins, 'long finger' type. Helps drip oil back into lifter galley rather than in the top of the head. These aren't great, some rust. I don't have a sand blaster to remove so they've sat for a couple of years
$20
*used* 2V Holley replacement Carb. Bought new and ran on truck for about 4,000 miles at the most before I tore the truck down to rebuild the engine. Never ever had a problem with the carb and it was a huge improvement over the motor craft 2100 the PO had on the engine. This dropped right on with no modification on the stock intake, linkage or kick down.
$100
1969 F250 Camper Special, 390 2v, C6, PB, Bendix PS, AC, Dana 60. 3rd owner
Soon rebuilt 390, not stock, will be swapped in.
BigFoot
Re: Misc FE parts
Post by BigFoot »
i 'm interested in the holly carb. I have some parts for trade but also cash.
I'm in chicago.
colnago
Re: Misc FE parts
Post by colnago »
I'm sure it will, but gotta ask. The starter will bolt up to a 352/360/390 with a C6 tranny?
Joseph
habu
Re: Misc FE parts
Post by habu »
@BigFoot, Send me your list. I have a 69 CS. Probably something I could use. If not we can work something out.
@Colnago, It should it bolted up to my stock C6, couldn't 100% verify about the 352. Now I ran into problems with the starter motor housing being about 1/2 too long on the Thorley headers I have. It should fit no problem with stock manifolds, but I couldn't say for sure. I can supply the dimensions if needed.
I do already have a PM from someone else, but if that falls through I'll let you know.
Now that I am so very close to being done my wife wants all the spare parts gone... :lol:
CharlaineC
Re: Misc FE parts
Post by CharlaineC »
i'm interested in the timing set up. are there any parts your looking for as i'm on a tight income
habu
Re: Misc FE parts
Post by habu »
a couple small things.
Brake warning light & bezel
The door jam light switches
maybe a couple of other small items.
PM me and we can work something out.
