67' F350 rear wheel seals
The passenger side and driver side rear wheel seals have started leaking on my 67'. I know this generation of trucks had some oddball variation of the Dana 70, is it going to be difficult to find a pair of seals? I'm not coming across much online.
Re: 67' F350 rear wheel seals
I'm not sure what "wheel seals" are. Can you look at the following diagram and give me a number?
http://www.fordification.com/tech/image ... oating.jpg
- guhfluh
That diagram can't be correct for a full floater Dana 60, 70, etc. Maybe for a Dana 44. East thing to see is 5 lug axles with hub flange vs. 8 hole axle only. Full floaters axles and hub assemblies are totally different. Full floaters have hub/drum/bearing assembles that bolt on with one large nut. The axle bolts to the hub with 8 bolts on the outside of the truck/hub and can be removed without even pulling the wheel.
It might be mixed in with a later year version's diagram, I just don't have the Internet resources to do the research at the moment, but I hope that helps some.
*edit* Here ya go: http://www.fordification.com/tech/image ... oating.jpg
1001 can be substituted with RTV, etc. 1175 is probably what he needs Keith.
'96 Dodge Ram ECLB CTD
'05 Infinity G35 Sedan
Looks about right, too bad ford probably discontinued it 30 years agoguhfluh wrote:That diagram can't be correct for a full floater Dana 60, 70, etc. Maybe for a Dana 44. East thing to see is 5 lug axles with hub flange vs. 8 hole axle only. Full floaters axles and hub assemblies are totally different. Full floaters have hub/drum/bearing assembles that bolt on with one large nut. The axle bolts to the hub with 8 bolts on the outside of the truck/hub and can be removed without even pulling the wheel.
