4 x 4 hubs
aearch
4 x 4 hubs
Post by aearch »
so bolts came loose
stripped out the lug bolts
can i use a 72-79 4x4 hub on a
66 4x4 they look the same
front hubs with warn locks
thanks
alan
Re: 4 x 4 hubs
Post by cep62 »
I think '76-'79 are from '75 and earlier. Disc vs drum brakes.
the earlier one should fit but the lockout might be a problem.?
if it's just the lug studs ,you can drive them out and install new ones fairly easy.
