1971 F350 Flatbed build...slowly
As some of you know I recently bought a 1971 F350 Flatbed from a local guy for $600. It had some massive side boxes on it,a diesel transfer tank and A LOT of parts,bolts,and junk in it...most of which is getting scrapped. I am going to try to keep a running total on this build. I will have plenty of questions also . Anyway here are some pics from it sitting in a field to now.
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..
Re: 1971 F350 Flatbed build...slowly
Interior and engine....this thing is all original w/ 41,000 miles. Has sat in that field for 15+ years
Plans are to get it all cleaned up and running well. I need to figure out what wheels I am going to need to get rid of these split rims. I am going to replace the wood planks on the bed floor with stained planks,and repaint the bed frame Seafoam green to match the truck again. I may eventually replace the 360 with a 460....this is going to go slow,but it will go.
- Alstoyz
That is one sweet find!!! I am so jealous. I see it came with a super cooler rad also!!! Keep the updates a coming. I'll be tuning in.
1970 F-100 SWB Tubbed
1971 F-250 Crew-Cab Dually
1972 F-100 SWB 4X4
1972 F-100 SWB 4X4
- jimmy828
great find . I've seen some awesome looking flatbeds in past. Like to have one myself.
- averagef250
Looks like you got a great deal on that guy. From the pictures it looks like some heavy cleaning and an easy paint job would have it looking like new.
- tylerb43
Wow, that's a deal. $100 worth of scrap and a $50 bench vise? I'd say that's a steal for $450!
Can't wait to see the updates!
- Alstoyz
Man. If you were a little closer, I've got a complete 1-ton disc brake/I-beams from a 75 dually I could hook you up with...
1972 F-100 SWB 4X4
1972 F-100 SWB 4X4
Where is Mangum OK from you? I have a friend that works out here and lives in OK. He will be going back there in about a week or 2....He will be driving I-40.
Man I'm hoping I have a LOT more than a hundo in scrap! Out here it's like 270-280 a gross ton...which they say is 2,240lbs. I'm sure I will be close to that with all the large(2" and bigger) bolts and solid steel pins that were in this thing. As for the vise, I would like to get rid of it..I already have a nice one....so if someone wanted to give me $50 plus the ride...it's THEIRS!tylerb43 wrote:Wow, that's a deal. $100 worth of scrap and a $50 bench vise? I'd say that's a steal for $450!
These tool boxes are on a 1/4"-3/8" I-beam and C-channel frame,plus there is a WHOLE LOT of 2"x1/8" angle and 1/8" plate all over it.
- Alstoyz
Magnum appears to be roughly 200 miles NW of me. I'm 60 miles due north of DFW.
1972 F-100 SWB 4X4
1972 F-100 SWB 4X4
no pics yet, but I got the utility bed all cut up and swept the flatbed off ...gonna need new wood,but it's nice to see that ole truck without that funky utility bed!
I will get some pics up soon....
OH BTW I also got it running...purs like a kitten! I did remove the water pump,water outlet,heater hoses and fittings. The system was DRY...and the water outlet had corroded so bad that all the aluminum and corrosion had filled the outlet closed! Anyhow,since all I have to do is remove the harmonic balancer and timing cover, I might as well do a timing set and front seal.
