Motor ID
A place for new members to introduce themselves
ramtoo
Motor ID
Post by ramtoo »
1968 F100 has 360 on Air cleaner but oil drain plug is over frame crossover for motor mounts ,so thinking this is a replacement engine! Oil tube mounts on driverside exhaust manifold bolt Anyone know of a easy ID besides the piston highest point method? Also was starting till I let it go to long between starts this winter. Battery shows 12.4 volts after charge but will not start and wont jump from solenoid. Thinking starter is stuck any suggestions?
Thanks
Re: Motor ID
:wel: from Georgia! Our solenoids are known to go bad suddenly and even be bad right out of the box. Stick a voltmeter on the battery and check for a drop in voltage when you turn the key. Battery may check fine unloaded but have a bad cell and voltage drop under load. Let us know what you find out.
fireguywtc
Re: Motor ID
Post by fireguywtc »
:wel: from Texas! :fr:
Bill
Mohillbilly
Re: Motor ID
Post by Mohillbilly »
Welcome from SW Missouri. The battery should read from 13.0 to 14.5 volts when charged. Sounds like you've just got a weak battery. Is it sealed, or can you check the acid level and concentration level? Winter always brings out the weakness of almost everything on our old trucks. Good luck.
70 Custom LWB, 302-2V, 3 on tree
ramtoo
Re: Motor ID
Post by ramtoo »
Yes I thought I needed new bigger battery but wont jump start off another running car , even tryed neg to motor to bypass bad battery but no go! To pull the starter have to remove right side headers Done this before and always had to torch out broken bolts from heads :cry:
Thanks for the responce
Ramtoo trans plant from St. Louis to Texas and I don't miss the Taxes or winters from Missouri!
Mancar1
Re: Motor ID
Post by Mancar1 »
Welcome aboard from Northern Ca
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
lennyp
Re: Motor ID
Post by lennyp »
:wel: from Massachusetts.
Mohillbilly
Re: Motor ID
We probably need to move this topic to either Engines, or Electrical since this is the Welcome Mat. At any rate, Welcome again.
