I'm looking for a steering column for my 71 Ford Ranger XLT.
Automatic Transmission.
I'd like to find a set up complete from the steering wheel down to the coupling hook up under the hood. I've never pulled/installed one before, but it looks like that would be the easiest way to go.
Thanks,
Bob
71 Ranger XLT Steering Column needed
71 Ranger XLT LB 2WD
Tilt Steering, West Coast Mirrors
390, 9.5-1 C.R., Holley 600, D2 Heads, C-6
Custom Grind Oregon Cam
Flotech Headers, 2.5" Duals w/H-Pipe
- basketcase0302
Re: 71 Ranger XLT Steering Column needed
Bob,
Tilt steering is one of the easiest upgrades we can do to our trucks-highly recommended. Here's a Bronco column that I know would bolt into the cab-but I'm not sure if the overall length would be different than the truck column? You'll also never see on for this price again-I believe he listed it funny so it doesn't show up for a lot of folks?
http://www.ebay.com/itm/150951852927?ss ... 1423.l2649
And here's the tilt steering tutorial:
http://www.fordification.com/tech/tilt.htm
I will add that there are a few variations to the tilt wiring that you may run into, but nothing you can't get past.![Wink :wink:](./images/smilies/icon_wink.gif)
- bluef250
My 71 truck does have power steering. I don't know whether this is a concern, or not. The tilt steering sounds nice. I may end up going that route. I'm just now starting to check around - an have limited cash right now. Thanks for the tips, guys!
Bob
Bob
Well, finally got with my mechanic today - first words outta his mouth were, "If you're going to do this, you ought to get a 78/79 Ford Steering Column w/Tilt Steering". Thanks, guys. I'm definitely considering that option. I really appreciate the info.
Bob
Bob
Does it matter whether the 78/79 Bronco Tilt Steering is from a 4WD or not?
Does it matter whether or not it had Power Steering or Manual Steering?
Mine is Automatic Transmission w/Power Steering & 2WD.
Thanks,
Bob
Thanks,
Bob
PM Sent...
68 F-250
79 F-150 4x4 (parting out)
79 Bronco (parting out)
