My 1970 F100 CV Build
Re: My 1970 F100 CV Build
Gonna do the crown vic front end swap
Got the donor car for it
got front end out
and cleaned up some
got front end out
and cleaned up some
Cab off
motor and trans out
started cutting out old suspension
new going in pretty good
made some tubing spacers
fixed rusted out cab mount
got rear control arm mounts fab up and mounted
got frame all ready for sandblasting
- fbomb100
cool your on your way
Very nice start.
Very impressive. Nice welds.
- flyboy2610
Looks good! You have the same type of engine hoist that I have.
Red Green
you'd better be right.
Red Green
What were your measurements like? Did you mach up the fenders before you bolted it on?
- fbomb100
this is'nt the frist time this has been done to our trucksdiznasty wrote:What were your measurements like? Did you mach up the fenders before you bolted it on?
I'm well aware. I'm in the middle of my own swap. After adjusting and taking fenders on and off I am just looking to compare some measurements.fbomb100 wrote:this is'nt the frist time this has been done to our trucksdiznasty wrote:What were your measurements like? Did you mach up the fenders before you bolted it on?
