converting dent axle to 5x4.5...
70shortwide
Post by 70shortwide »
I need to convert my dent f100 axle to the car 5x4.5 lug pattern... anybody know if theres a car axle that will slide into this housing? I can have these ones redrilled, but if I can run to U Pull It and snag a couple axles I would likely just do that. :fr:
ultraranger
Re: converting dent axle to 5x4.5...
Post by ultraranger »
70shortwide wrote:I need to convert my dent f100 axle to the car 5x4.5 lug pattern... anybody know if theres a car axle that will slide into this housing? I can have these ones redrilled, but if I can run to U Pull It and snag a couple axles I would likely just do that. :fr:
If you can locate an '80-'83 F100 in the wrecking yard, it will have a wider 9-inch rear end (which will be very close to matching the width of the CV front suspension), and the axles will have the correct 5-on-4.5" lug pattern.
If you locate a possible donor truck, just be sure to measure the lug spacing before paying your money for it.
Steve
tybob81
Post by tybob81 »
Driver side axles off a 77 Thunderbird is what I have always used.
