engine turns over but won't crank
Took motor out of a 79 ford. It ran fine in that truck. Put it in a 72 ford and cant seem to get it to start. It turns over all day but wont crank any suggestion
- fireguywtc
Re: engine turns over but won't crank
![Welcome :wel:](./images/smilies/icon_welcome.gif)
![FORDification Rocks! :fr:](./images/smilies/icon_FORDification.gif)
Bill
- basketcase0302
The motor is a 302 and it has electronic ignition from the 79 truck I also changed both boxes to the 72 truck and checked the wiring harness three times to make sure it was right
I haven't checked the sparkplug but it is pumping fuel I have bought a voltage meter but nor sure what to check
- basketcase0302
Here's a good wiring diagram for the Duraspark ignition the 79' would've had:
http://www.fordification.com/forum/view ... =8&t=48178
I'd start by checking to see if you're getting power, (8-12 DC volts) to the + side of the coil when the ignition is switched on. And pull a spark plug and ground it against the block to see if it's firing. You should have a nice bluish/reddish spark when turning the engine over-and grounding the plug against the engine block. Duraspark is also very easy to short out, (box wise). But the beauty of it is that it is also fairly cheap to replace:
http://www.ebay.com/itm/Motorcraft-Dura ... 21&vxp=mtr
And you might want to start another thread on your engine issue over here, (rather than in the "Welcome" board:
http://www.fordification.com/forum/viewforum.php?f=3
Welcome from Indiana...
68 F-250
79 F-150 4x4 (parting out)
79 Bronco (parting out)
I did all that and I don't have any fire at the number one plug does that mean the coil is bad how do u check that
Rechecked all the wiring and put new coil on today still no fire to the plugs what to do next anyone with an idea please help
- basketcase0302
Back to my question above...do you have a voltage meter? If so, what are you reading on the 12V "+" side of the coil with the ignition switch turned on?grabbitwilson on Sun Sep 09, 2012 8:43 pm
Even with the new coil I'm. Still no getting a reading on the coil with the switch turn on what does that mean
Personally, i'd start backtracking the circuit from the coil backwards. Do you have power at the other end of the connection, etc.
No wire to the switch everythings ok now thanks
![Woohoo! :woohoo:](./images/smilies/icon_woohoo.gif)
