Tires won't spin when stuck- auto trans.
jumpinjivinjoe
Post by jumpinjivinjoe »
I have had a couple of occasions where my wheels won't spin on my 1969 F-250.
For Example:
I was towing my 3,500# 21' flatbed trailer up a slight incline in my pasture. I could only get up to one point. Pedal to the metal; but the tires would not spin. My other trucks would have torn up the grass instead of not spinning the tires at all.
I was getting some fill dirt and got into some really loose dirt up to the axles. Once again pedal to the metal, tires would not even spin. (Had to dig it out and come-a-long it with my subaru).
I think the tires should either spin or the engine should die when I am stuck in these situations.
What could the problem be?
Thanks for help!
1957 Mercury Monterey
1936 Dodge coupe
1969 Ford F-250 (360)
fbomb100
Re: Tires won't spin when stuck- auto trans.
Post by fbomb100 »
maybe your timing is a little retared and u may need gears .. or your motor is warn out and it was to much of a load for it! did u drop her down in to first(i 'm sure u did)
jumpinjivinjoe
Yeah that could very well be true. I strongly suspect I need a new timing set put in, in fact I intend putting a new timing chain in the next couple weeks. Hopefully that helps!
1936 Dodge coupe
1972hiboy
Post by 1972hiboy »
yeah sounds like you powered out. tired motor? how many miles does it have under its belt?
Rich
Dont eat yellow snow.....
jumpinjivinjoe
I reckon the timing chain has never been replaced. I intend to change it in a couple weeks. It has all the symptoms of worn chain. I would think that the engine would have simply died if the wheels could not spin, which made me think it was a slipping trans. Hopefully a new timing set will change all the truck problems...Hopefully.
1936 Dodge coupe
Whateverman
Post by Whateverman »
did the engine load up or did it rev and the tires not spin?
if it revved ,then your trans is weak (or you don't have enough atf in it)
