Very nice used 390/410 pistons .030 over
I took these cast Badger pistons out of my truck, I put them there approx 15K miles ago brand new. Ther have NOT been cleaned, this is exactly how they came out of the motor. I took pictures from every angle so you could get a good look.
I won't tell you to reuse rings, but you probably could stick these in the hole with the same rings and they'd run fine. The truck didnt burn a drop of oil and ran great with no measurable ridge and the bore still had a clean crosshatch
With a 390 crank, they are .130 below and 8:1 compression, but the beauty of these is that they really were built for a 410, with a 428/410 3.98 stroke crank, they are approx 9.5:1 and perfect a torquey truck.
I pulled it apart because I decided to build a 445 FE
Looking for 100 bucks for the pistons, 150 if you want the rods too, plus shipping from 68133
Email or PM me, My427stang AT cox.net
410 pistons for sale
- My427stang
