![Laughing lol](./images/smilies/icon_laughing01.gif)
![Image](http://i770.photobucket.com/albums/xx341/LDForget/IMG_1468.jpg)
![Image](http://i770.photobucket.com/albums/xx341/LDForget/IMG_1467.jpg)
![Image](http://i770.photobucket.com/albums/xx341/LDForget/IMG_1466.jpg)
![Image](http://i770.photobucket.com/albums/xx341/LDForget/IMG_1469.jpg)
![Image](http://i770.photobucket.com/albums/xx341/LDForget/IMG_1464.jpg)
![Image](http://i770.photobucket.com/albums/xx341/LDForget/IMG_1463.jpg)
![Image](http://i770.photobucket.com/albums/xx341/LDForget/IMG_1462.jpg)
![Image](http://i770.photobucket.com/albums/xx341/LDForget/IMG_1461.jpg)
![Image](http://i770.photobucket.com/albums/xx341/LDForget/IMG_1460.jpg)
![Image](http://i770.photobucket.com/albums/xx341/LDForget/IMG_1465.jpg)
The chevy box isnt going to be staying on the truck. It had a flat bed and the chevy box is sitting on it for now. Ill likely install it until i can find a good deal on the box.
Im not sure, i dont remember. I think their pull knobs. Ill take a pic when i go visit it again, haha.kf7mjf wrote:Nice save! Yeah, frankenbump for sure. What does the dashboard look like? If you have push pull knobs for heater controls and the like, its a 67.
Ill take a look, good call. I think i read that somewhere on here as well in the tech library.fireguywtc wrote:from Texas!
The frame is obviously a highboy frame because of the eight lugs and divorced transfercase. On the top of the right frame rail somewhere behind the axle there should be a vin# stamped into the medal, that will be your trucks true idenity since the rest of it is such a mutt.
I was having the same ideas about the truck,that the cab is original and the doors/hood are not, but then i was thinking, is there an option for dana 60's front and rear on the f100? maybe its a f250 frame/doors/hood/diff/ect and f100 cab was swapped on? And yeah, its a chevy bed, haha. My boss has a old ford sitting in the yard that has a flare side bed that im probably gonna snag for cheap. Its a early/mid 80's.Calfdemon wrote:Nice save! Looks like you have your work cut out for you though. That bump is a little toasty, but every bump is worth saving.
I would guess that those doors are not stock to that truck, so more than likely, the vin tag on the door went to another truck. That hood (or at least the hood markers) are not original to that truck either. If that truck is a 67, those hood markers are 68-72 and those FORD letters are 70-72. The holes for the FORD letters are in different locations than the 67-69 letters, so that is probably a 70-72 hood. So it very well could be an F100. I would probably assume that the cab is original to the truck, so if that 2nd VIN tag is on the cab, that is probably the actual VIN for your truck.
I dont even have a clue what the bed is from... Is that a Chevy bed??
You definately have a "Frankenbump" there. If you go to the tech section of this website, there is a TON of info to help you decode the different VIN's and tags to help you figure out what you are dealing with.
ahhh!! Thanks!stephen44 wrote:if you look at your door - see the raised profile body line half way down - it's a 'bump'
the later ones go in at the same point - hence 'Dents'
