New to This Forum [from Camden, Arkansas]
A place for new members to introduce themselves
ultraranger
Post by ultraranger »
...well actually, I've been "lurking" here for a little over a year now. I just haven't made any replies until recently.
At any rate, hello 5th generation F100 owners!
My name is Steve and I live in Camden, Arkansas [south-central part of the state]. I've been a Mustanger most of my life. I bought my first vehicle ['68 Mustang] two weeks before I turned 16, in September of '82. 30-years later, I still own my high school car. For the past 11 years or so, I've posted at several vintage Mustang sites under the board name, 'ultrastang'. Now that I have an F100 and a "reason" to be here, it just seemed natural to use the name, 'ultraranger'. :wink:
While the '68 Mustang was my first vehicle, it wasn't the first vehicle I learned to drive. The first vehicle I learned to drive was my dad's red & white '68 F100 Ranger, which had been upgraded with all '70 model interior and exterior trim. It had a 360 with a 3-on-the-tree. Only 'creature comfort' it had was A/C.
I had a chance to buy a very solid '69 SWB F100 Ranger in April a year ago, so I jumped on it. Currently, it just has the 240 inline 6, C-4 automatic, drums all the way around, 9-inch w/3.50:1 single track diff. No A/C or power steering but I did recently add a power brake booster from a '75 Ford F350 1-ton truck to my '69.
I have a 5.0L H.O. fuel injected engine from a '90 Mustang GT that will replace the 240-6. A Ford 4R70W electronically shifted 4-spd overdrive automatic transmission from a '98 3.8L Mustang will replace the C-4. The 9-inch will be replaced with the IRS rear setup I got from a 1990 Thunderbird Super Coupe which has rear discs, an 8.8" center section with 3.27:1 gears and a Traction-Lok differential.
My '69 Ranger as it currently stands:
1. Image
2. Image
3. Image
4. Image
5. '03 Crown Vic front suspension & '90 T-Bird Super Coupe IRS rear suspension:
6. 3.8L '98 Mustang 4R70W overdrive transmission:
7. 1990 Mustang GT 5.0L H.O. fuel injected engine that will be going in the truck instead of the '68 Mustang:
8. The general idea of the look of the truck when it's complete:
Steve
fireguywtc
Re: New to This Forum [from Camden, Arkansas]
Post by fireguywtc »
:wel: from Texas! :fr:
Bill
wndsofchng06
Post by wndsofchng06 »
welcome, cool concept!
1970FordTK
Post by 1970FordTK »
Welcome from North Carolina. :thup:
tidybowl
Post by tidybowl »
welcome from SoCal. Nice truck way cool motor.
1970 F-250 Camper Special 390/C-4 auto 289K miles, 1992 Explorer 4x4 229K Miles, 2000F-150 4.2L V6 154K miles
basshound71
Post by basshound71 »
Looks good and sounds even better. Glad you joined from West Memphis,AR
1971 Ford F100
2007 Chevy Avalanche
Kurt Combs
Post by Kurt Combs »
:wel: from northern California.
Kurt
1972 F-250
:wel: from Georgia! Great truck and awesome plan!
XABN82
Post by XABN82 »
Welcome from Chattanooga. Man that is one nice looking 69. Good luck and don't forget to post in the "Project Update" section when you start the work on the truck. :wel:
Montana71-F100
Post by Montana71-F100 »
Welcome from Montana! Nice truck!
feefie
Post by feefie »
Awesoem ride!! I may need to take a drive down south Arkansas way sometime and check out your rig. Very nice!
Stu
Doing what is right isn't always easy....doing what is easy isn't always right.
1968 Mercury M-250 clone
1976 F-250 Highboy
ultraranger
feefie wrote:Awesoem ride!! I may need to take a drive down south Arkansas way sometime and check out your rig. Very nice!
Stu
Thanks. My truck is far from flawless but is very solid for a 44 year old truck.
I'm guessing you are somewhere in the Little Rock, North Little Rock, Jacksonville, Cabot, Benton area?
Steve
lennyp
Post by lennyp »
:wel: from Massachusetts. Nice looking truck. Good Luck.
Mancar1
Post by Mancar1 »
Welcome aboard from Tehama County Ca
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Craigerf100
Post by Craigerf100 »
Nice truck ranger :thup:
I've been contemplating going fuel injection on my 302.
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build: :fr: http://www.fordification.com/forum/view ... &sk=t&sd=a
