unknown part 72 ranger
hello, this part is under the hood on driverside on the inner fender near the radiator support, it's a hinged bracket with a threaded stud from the inner fender????? maybe you might also know where i can decode the build sheet i found under the bench seat, it has a lot of info, much more then the data plate on the door. 1972 f100 ranger 360 w/AC, long bed. thank you for any help!!! kevin. sorry i dont have a camera with low enough mp to post a pic now.
Re: unknown part 72 ranger
Maybe the bracket that holds the factory jack
1971 Ford F100
2007 Chevy Avalanche
Thank you for your reply, i did find out and you were right, now i need to find a jack for the holder!! Kevin.
- basketcase0302
Kevin, you can grab one of the screw-type jacks that fit into the bracket from almost any bump or dent era Ford truck, (73-79) as they didn't really change much.kevins72 on Mon Jun 04, 2012 4:03 pm
Edit for part link:
Here's the type of jack you'd be looking for, believe I might have one here too. PM me if interested.
http://www.ebay.com/itm/1949-50-51-52-5 ... 06&vxp=mtr
Last edited by basketcase0302 on Mon Jun 04, 2012 8:23 pm, edited 1 time in total.
- Kurt Combs
You can resize your pictures in Windows Paint program really easy. Check it out and if you need more directions I can go through the process and write down some directions for you.
Kurt
1972 F-250
1972 F-250
