Who ever can help me, I would be thankful
I have a 69 f100 360 4 on the floor with a 3.73 and i was wanting to change the tranny out but i do not have an idea what i should put in. If anyone has a recommendation i would be happy to hear it.
hot roding my 69
- Bob
Re: hot roding my 69
Hi and welcome to the forum...
I'm guessing you are changing the tranny because something is wrong with it?
Or are you wanting to go automatic?
Myself... I'd get the one you have rebuilt or find the same thing in a junk yard and slap it in. New clutch kit also...
there is nothing wrong with the tranny its just with the current set up I am only able to get to 70 in 4th with rpm at 2800. I neglected to tell you that it also has the granny low for first.
- Bob
If you're looking for more speed you're gonna want to change the ring and pinion gears in the rear. You say 3.73 to 1 are in it now... correct? If you go much more in the speed direction... (smaller number in the ratio = higher top end) you will sacrifice torque.
Trucks were never really meant for flying around so most came with 3.73 to 1 or 4.11 to 1 gears in them. Probably depends a lot on the area in the country too. Hilly areas the 4.11's are nice. Flat landers can go to the 3's.
Far as the granny 1st goes... I never use first except when I park it. The first gear in these old trucks is just for decoration.
you are correct I do have the 3.73 and i live in arizona so its about 50-50 on the terrain but i mainly stay on the flat lands... but your saying stay with the tranny that i have and just change the ring and pinion gears.
- Bob
I wouldn't change anything... Especially in an old pick-up... They don't handle well enough for me to feel comfortable in an old Ford going a hundred.
You might want to consider one of those two speed gear box gadgets that somebody out there sells. Gives you a high and low range with what you have. You can run regular or or change the box to a sort of overdrive mode.
Might also be able to find a 5 speed out of something newer with overdrive that'll bolt up with little or no modifications?
- HIO Silver
Ummm... that's not hot rodding....I wouldn't change anything... Especially in an old pick-up... They don't handle well enough for me to feel comfortable in an old Ford going a hundred.
It's not cheap but since ya asked - look into a Quicktime bellhousing and a Tremec TKO-500. Alternatively, a Gear Vendors Overdrive.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
sweet thank you
- mrtleavitt
Here are a few threads that explain what I did. Least expensive, using original ford parts, and very simple if you're already are running a 4 speed.
Look for my posts in these threads.
http://fordification.com/forum/viewtopi ... 19#p291579
http://fordification.com/forum/viewtopi ... 19#p367445
http://fordification.com/forum/viewtopi ... 19#p452515
Let me know if you have any other questions!
