4x4 bumper brackets
ptodave390
4x4 bumper brackets
Post by ptodave390 »
need the stock front bumper brackets for 1972 f 250 4x4 also looking for straight chrome stock bumper
Doug Comer
Re: 4x4 bumper brackets
Post by Doug Comer »
the ones from a two wheel drive F350 work also.
Doug
1967 f100 4x4
1970 f250 4x4
1971ford
Post by 1971ford »
And from what I've seen at the junkyard (when I got mine), the f350 ones are bolted in and the highboy ones are riveted so f350 ones would be easier to pull.
Not sure if this is always the case though.
-Ryan
Doug Comer
I thought I had a et for you today. Was at pick n pull and they had a f350 with the brackets. I was all happy. Got the bumper off and found the bottom bolt holes had rivets. I didn't have a big enogh chisel to cut them off. Sorry man, I tried. Maybe someone close to the pick n pull in Stockton ca can grab them for you.
Doug
1967 f100 4x4
1970 f250 4x4
ptodave390
thanks for the f 350 tip will keep looking
