I'm looking at putting a set of stainless steel trans cooler lines on my C-6 from inline tube.
My truck was originally a 3 speed on the column and I took a C-6 out of a 78 dent side.
My question is, are all the lines the same? or will I need to buy a set for a 78?
Thanks, Cole
All C-6 lines the same?
Re: All C-6 lines the same?
The fittings on all C6's are the same size..Where you may run into problems is the bends & configurations used on different body & engine styles.
May I ask why you are using stainless? Are you building a show truck? If not, you can use Bundy flex brake line from any auto supply...Donnie
- Kurt Combs
The lines have different configurations, dependent on the radiator's lower tank.
Kurt
1972 F-250
1972 F-250
How would one figure out which lines to get? I'll check the radiator off the donor, but i believe there pretty close to my 71 radiator.
My build thread...http://www.fordification.com/forum/view ... 22&t=67317
anyone else?
- BobbyFord
Buy stainless steel tube stock and a bender and bend your own. Use the cheapy stock crap from your local parts store first to make some patterns.
