So my rebuilt Dana 44 which is a king pin axle, has 4.10 gearing currently. The rear is 5.38... I didn't have the shop that installed my new D44 install my front drive-shaft since i have to order a 5.38 ring & pinion for the front. Can i order a 5.38 Ring & pinion for a D44? Like this http://www.summitracing.com/parts/MGR-D44-538/
Or is there certain ones for king pin axles or ball joint axles? Or does Spline count Matter?
Thanks for any info,
Ryan
Dana 44 Ring & Pinion Gears
1970 Ford F-250 Highboy, flatbed, 390 with C6, 8" lift, 39" firestone TX's, Dana 44 front, Dana 60 Rear, bull bar
- averagef250
Re: Dana 44 Ring & Pinion Gears
There are high pinion and low pinion gears. No difference closed knuckle or balljoint or spline count. D44 carrier break is 3.92 so your 4.10 carrier will work with 5.38's.
FWIW Motive gears are at the bottom. Cheap out on a gearset and driving will be a constant reminder that you did.
Ok, what ones would you recommend.
- michael69
Richmond or yukon
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
michael69 wrote:Richmond or yukon
So this one would be a good one?
http://www.summitracing.com/parts/RMG-SD4408/
- michael69
Yes,but try randysringandpinion.com You can usually get better prices from him. Also search web for ring and pinions you can find more places with cheaper prices than summit.
Michael69
summit has some of the cheapest shipping i can find to Alaska, but ill look aroundmichael69 wrote:Yes,but try randysringandpinion.com You can usually get better prices from him. Also search web for ring and pinions you can find more places with cheaper prices than summit.
- cowbay
Ryan_1 wrote:summit has some of the cheapest shipping i can find to Alaska, but ill look aroundmichael69 wrote:Yes,but try randysringandpinion.com You can usually get better prices from him. Also search web for ring and pinions you can find more places with cheaper prices than summit.
I almost always shop with Summit for this type of parts. But do yourself a favor scan the internet for prices, call them up and they will beat the price by a dollar. It all adds up in the end. Also I prefer Summit because they are a reputable company and if there is a problem they will try and help you out as much as possible. They have for me. Just my
"If it can't be fixed with a hammer, then it is an electrical problem"
69 Ford F100 Ranger 390 3spd with overdrive
63 Chevy Impala 327 with 4spd. In the family since brand new. Over 280,00 miles
