hi all...i know them as automatic and manual...i also have always thought of a manual transmission as a gearbox...thanks
API GL-5. Oils for severe conditions. They contain up to 6.5% effective antiscuffing additives. The general application of oils in this class are for hypoid gears having significant displacement of axes. They are recommended as universal oils to all other units of mechanical transmission (except gearboxes). Oils in this class, which have special approval of vehicle manufacturers, can be used in synchronized manual gearboxes only
what does mechanical transmission mean
- thebannister8
- averagef250
Re: what does mechanical transmission mean
That's terrible wording.
That's synthetic oil for differntials, but can be used in stick transmissions that are made specifically for it. The materials used in the construction of synchros and shift forks are the determining factor. When unsure do not use that oil.
A mechanical transmission is any device that transmits rotational power through mechanical means. Pretty broad terminology.
- thebannister8
thank you for the information...i appreciate it
