New Engine for The "Speed Bump"!
- SVT522
Getting ready to set a new engine in my '67. It started life as a 1968 429 Thunderjet. It was cast in November 1967 so it should feel right at home in my '67 frame.
SVT522
ASE Master Automotive & Medium/Heavy Truck Technician
"The Speed Bump" 1967 F100 - 466 "Cobrajet", C-6 trans, 4.11 Detroit Locker
1969 F100 4x4 - 360, NP435, Dana 21
1973 Mach1 - 351 CJ, C-6, 9-Inch
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Ported A-429 Cobrajet heads.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Scorpion roller rockers.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Edelbrock Performer RPM port matched to Cobrajet port.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Billet converter.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Tubbed for 315/60-15 drag radials.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Body work finished, primered, block sanded twice w/ guide coat, ready for color.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Cab shot.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Frame painted top and bottom.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Ford 9-inch, 4.11s, Detroit Locker.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Cab corners in progress.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Replaced all the brake lines. Bent them myself and reflared the ends.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
In primer w/ guide coat ready to block sand the first time.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Lincoln Mark VIII 2-speed electric fan ready to cool the beast. I discovered this will not work with a 429/460. The fan motor and the water pump pulley want to occupy the same space!
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Re: New Engine
Rebuilding the C-6. Five clutches in each pack, widest rigid band you can get, roller #9 thrust bearing, D servo with D lever, Transgo shift kit.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
