rear end swap
fonfixer
rear end swap
Post by fonfixer »
would a posi traction from a 67 camper special lwb swap with my 67 swb without hunting for new driveshaft or any other major headaches?
1967 F100 swb 240 single barrel, manuel choke, three on the tree, style side
1967 F100 swb 240 single barrel, manuel choke, three on the tree, flare side
2011 F150 Crewcab Lariet w/Ecoboost (runs like a scalded dog!)
2019 Transit
70_F100
Re: rear end swap
Post by 70_F100 »
Depends. :hmm:
IIRC, in '67, a Camper Special could be either 1/2 ton or 3/4 ton.
Since yours is a SWB truck, I'm assuming (ouch) that it's a 1/2 ton.
Give us some more details about both trucks and we can give you the correct information.
fonfixer
Re: rear end swap
Post by fonfixer »
both are 1/2 ton, 2 wheel drive
2019 Transit
forrestbump
Re: rear end swap
Post by forrestbump »
fonfixer wrote:both are 1/2 ton, 2 wheel drive
Next question: Are they both Ford 9", Dana 44 or, less likely, Dana 60 (NON full floating)? All three flavors can be found in F100's.
If they are both 9" Ford with matching spline count (usually 28 spline) then YES, the parts will interchange.
Larry
