Transmission going out? Please Help
rltvader
Post by rltvader »
Hey guys, I have a 1969 F100 with a 302 and a C4 Transmission. It is shifting but it is delayed more than usual, and at 60mph, it takes forever to shift into third gear, I am going to put some extra fluid in soon, if that doesnt work, what can I do?
-Built Ford Tough for a Reason
1969 F100 Red/White LWB (302)
1972 F250 Camper Special Ranger White LWB (FE)
BobbyFord
Re: Transmission going out? Please Help
Post by BobbyFord »
Check the vacuum source and the line going to the modulator valve. Also, pull the elbow hose off of the modulator valve and see if the valve is leaking fluid.
rltvader
Post by rltvader »
thanks, the fluid is still red so its not getting too hot, ill check tonight. It was fine last night, but today it was acting weird.
flyboy2610
Post by flyboy2610 »
Remember to check it when the engine and tranny are both nice and warm. Don't check it cold, it'll give you a false full reading.
Red Green
you'd better be right.
rltvader
Post by rltvader »
checked this morning after 30 min drive to school, said full
Donnie
Post by Donnie »
I'm with Bobby Ford on this one..If your 1/2 shift is late also, check your vacuum system from the intake to the modulator..look also for ANY leaks in the intake, E.G., a vacuum cap off???
Bad modulator valve....If there is nothing wrong in this area ..........repost...Donnie
