Caliberating the speedometer
bandit76
Post by bandit76 »
I have a 69 F100 with a 360 engine and a C6 tranny. Recently, I had to replace a 3.25 gear ratio rear end chuck with a 3.75. I checked against a GPS speed and I'm running a bit slower that what the truck speedometer is displaying. How can I fix this? Thanks for any help. :fr:
1969 F-100
1971 VW Superbeetle
BobbyFord
Re: Caliberating the speedometer
Post by BobbyFord »
You need a larger diameter speedo driven gear (more teeth).
Mancar1
Post by Mancar1 »
Bobby knows of what he speaks. :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
bandit76
Post by bandit76 »
Which speedo gear would I need or where could I find the info? I notice LMC has several different ones.
1969 F-100
1971 VW Superbeetle
flyboy2610
Post by flyboy2610 »
bandit76 wrote:I have a 69 F100 with a 360 engine and a C6 tranny. Recently, I had to replace a 3.25 gear ratio rear end chuck with a 3.75. I checked against a GPS speed and I'm running a bit slower that what the truck speedometer is displaying. How can I fix this? Thanks for any help. :fr:
Well, the way it is, you shouldn't get a speeding ticket! :lol:
Red Green
you'd better be right.
BobbyFord
Post by BobbyFord »
bandit76 wrote:Which speedo gear would I need or where could I find the info? I notice LMC has several different ones.
I don't have a Ford parts book, but since Ford did not offer a 3.75 option for our trucks you will have to go with your application but with a 3.73 rear gear ratio. If someone here has a parts book they can tell you the correct number of teeth, if not your local Ford dealer can help you.
70_F100
Post by 70_F100 »
In order to determine the correct gear, we'll need to know what size tires, also.
arent you suppose to add one tooth per so many miles per hour it is off?
bandit76
Post by bandit76 »
I found out the rear end chunk came out of a mid-70's ford pickup.
You got that right flyboy speedometer said I was going 60 MPH but reality I was only going 50 MPH.
@ 70_F100 I'm running 235 75 R15 if that helps.
1969 F-100
1971 VW Superbeetle
justiz00
Post by justiz00 »
When I went from a 3.25 to a 3.0 I went 1 tooth lower on the cable side gear. The speedo is off the same as it was with the old gears (incorrect tire size). I found the info here.
http://www.ford-trucks.com/forums/90208 ... tions.html
