turning a C6 into a married C6
Can I change a regular C6 transmission to accept an married NP205?
Re: turning a C6 into a married C6
Also does anyone have an idea of a good strong manual transmission that will link up to my 460 and a married NP205 semi easily. Right now its a 3 speed C6
Yes. You will need a short tailshaft and T case housing/adaptor. You have to disassemble the trans to do it, so it's a good time to get a basic rebuild kit and freshen it up.
1970 F100 Custom Shortbed Styleside
460/C6
460/C6
is that something that i can do in my garage with basic tools?
- averagef250
Time/money ahead to find a 4x4 version than switch one over.
NP435 and T-18/T-19's are common in the configuration you'd need to replace an auto.
look for a 73-79 c6 from a 4wd. to get the trans you need for the parts.
now are all C6 3 speed or do the come in 5
All C6's are 3 speed..They are the strongest 3 speed that Ford used,,They are used in 460 Lincoln---down thru the whole range.....The gear ratio is the same in all, but the drums, servo pistons , & valve body internals vary in all models........there are 6 diff servo pistons=these are for 2nd gear apply..The lincoln being the softest...folks driving these cars do not want to feel the shift...I think all you other questions have been answered....Yes , they are ALL 3 speed....There is a process where you can use E4OD gearing for 1st & 2nd, but the change is small & not worth the cost...........Donnie
some reason my C6 is taking a long time to shift, I feel it disengage but than it takes awhile for it to shift and reengage, is that a sign of it going out?
- flyboy2610
If you are going to get into the C6, don't do it without this book:
http://www.amazon.com/Automatic-Transmi ... 685&sr=1-3
I have this book and it goes into step-by-step detail on how to tear it down and rebuild it. I really recommend it.
As was said, if you're going to tear it down, now is a good time to rebuild it.
Red Green
you'd better be right.
Red Green
usmcjones1988 wrote:some reason my C6 is taking a long time to shift, I feel it disengage but than it takes awhile for it to shift and reengage, is that a sign of it going out?
First to 2nd or 2nd to 3rd ?? Could be serious, could be simple...For me to answer I need more info. I will refrain from detailed answers as I find they are mostly not appreciated on this forum........Donnie
"In order to make repairs to anything, it is a great advantage to understand how it works"
John DeLorean
when it shift from 1st to 2nd and it really rough when it shifts is it possible that it shift to late.
+1 on that book. I've got the Ford and the GM versions, both are great resources.flyboy2610 wrote:If you are going to get into the C6, don't do it without this book:
Josh
'72 F-100 Sport Custom 4x4
usmcjones1988 wrote:when it shift from 1st to 2nd and it really rough when it shifts is it possible that it shift to late.
The later it shifts=the harder it shifts.......Check your vacuum system real close..Hoses & modulator first..Is the shift from 2 to 3 also late?.........Donnie
i dont think it has every shift from 2 to 3 while i have drove it
