pinion bearing housing hot
- blumule
i replaced both pinion bearings , and torqued crush sleve to acheive about 20 inch pounds to spin yoke . this created a drag on yoke which i expected for new bearings. after a 20 minute drive i crawled under to check for leaks and noticed pinion housing to be hot. never noticed this before and was just curious if this is normal for this part of the rearend.how long before new bearings break in? Should i be concerned? Its not too hot where you cant hold your hand on it but it is still hot,
Re: pinion bearing housing hot
You are probably OK, just make sure that you are full up to the fill hole...Whose bearing's & what lube did you use?................Donnie
- blumule
napa bearings and 80w90 lucas gear lube
All looks good to me.............Drive on...........Donnie
