LOTS of FE 360/390 parts!!
Private parties only. No eBay/Craigslist listings.
1971ford
Post by 1971ford »
All parts are FE 360/390 parts, and all are off a FE that was in great running shape.
Prices without shipping unless otherwise noted.
-390 block, would need one cylinder sleeved. pick up only $40
-390 rods $40
-Starter index plate -$20
-Pulleys/dampeners - tons, let me know which one you need
-2 water pumps all good to go - $15 each
-2 mechanical fans - $10 each
-air cleaner, original style $20
-Brackets- I think i have ever bracket thats ever been on an FE including air compressor brackets... let me know what you need
-Water elbow off intake - $10 shipped
-Oil pump intake/filter from highboy - $10
-Ignition coil, i have several, $15 for all 3
-several radiator hoses upper and lower
-Oil filter mount - $15 shipped
-Motor mounts in good shape $15
-Engine mount towers from highboy coated in por-15 $20
-390 crank main caps $10
-Starter heat shield from summit racing $10
-Heated 2v carb spacer - $10 shipped
-Various fan spacers short and long - All of them for $20 shipped
-Alternators, i think i have 4, with different style plugs but all from bumps
-a/c compressor/brackets
-FE rebuild book I just bought a few days ago before i decided to go cummins, it's a great book. $15 shipped.
A couple of parts.
-Ryan
colnago
Re: LOTS of FE 360/390 parts!!
Post by colnago »
Any pics of the exhaust manifolds? Do you have a P/S pump with bracket? If no pump, do you have the bracket?
Joseph
1971ford
Post by 1971ford »
I'll get some pics of the exhaust manifolds right now. They're in great shape.
I don't have a P/S pump but i do indeed have a nice PS bracket.
-Ryan
67mann
Post by 67mann »
Ryan...what ya want for the carb and can i see a pic of the heat(starter)shield :thup:
1971ford
Post by 1971ford »
67mann wrote:Ryan...what ya want for the carb and can i see a pic of the heat(starter)shield :thup:
Just sold the carb, sorry! I'll get you a pic of the starter sheild :thup:
-Ryan
1971ford
Post by 1971ford »
here are the pics of the exhaust manifolds and the starter shield
-Ryan
67mann
Post by 67mann »
Day late...always a dollar short :lol: Guess the heat shield wasn't what I pictured
evolutioneng
Post by evolutioneng »
140 shipped to 77493?
how much for the valve covers?
evolutioneng
oops for the aluminum intake..
1971ford
Post by 1971ford »
PM sent evolution!
-Ryan
fusejockey
Post by fusejockey »
Can you please look at my ad & pix for Parts / Wanted: 352 carb spacer? Does the 2 bbl. spacer you have look the same, except for the heated ports?
I'm not sure what can be interchanged with the 1967 352 FE... my old spacer is cracked. (dog gonnit)
Thanks so much,
Stan
1967 F-100 352 FE w./ T-18 4 speed Camper Special, 116,000 original miles- 1978 F-150 {complete} Disc Brake front end retrofit.
"Six 7" has been in our family since new, from Read Mullan Ford...
http://s1211.photobucket.com/user/fusejockey/story/5043
:thup:
1971ford
Post by 1971ford »
Hmm, well the spacer you have is a pcv spacer, it has the port for vacuum. Mine is similiar but instead of a port for vacuum it has a port for coolant to heat the spacer up (coolant circulates around the spacer). Not sure if this is what you want.
-Ryan
whiteblur
Post by whiteblur »
how much for that ps bracket to 37312?
1971ford
Post by 1971ford »
Sold the PS bracket sorry :(
-Ryan
One_F250
Post by One_F250 »
I saw your post and was wondering if the valve covers pictured would be fore sale? (If you still have them) I know the post is about a year old, but I just thought I'd ask and see. Thanks!
