3.03 three speed output yoke torque rating?
Florian
Post by Florian »
Which is the right torque rating for the nut that secures the yoke on the output shaft on a 3.03 RAT three speed?
In the ´71 shop manual I found 60 - 80 ft.-lbs. However, in the ´64-´73 manual transmission service shop manual it says 40 - 50 ft.-lbs. for the "u-joint flange to output shaft".
´71 shop manual:
´64-´73 manual trans service manual:
Thanks!
Florian
1971 Ford F100, 302cui, 3 on the tree
