ford 3.03 question
1967mercury
ford 3.03 question
Post by 1967mercury »
how would i go about changine the fluid in my 3.03 tranny, and what fluid do i fill it up with???
1967 Mercury M-100
240 i6
3.03 trans
3300IB 9" 3.70 Gears
Re: ford 3.03 question
there should be a drain plug on the side of it down low. 80/90 weight is the easiest to find and fill it up with.
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
The factory shop manual says to drain the lubricant on the 3.03, you remove the lower extension housing-to-transmission bolt.
To refill it, you'll need a hand pump with a tube (available for $12 at O'Reilly's) , which you insert into the fill hole on the side of the case.
(Transmission shown isn't a 3.03, but you get the idea.) :thup:
1967mercury
big help guys thanks!!
1967 Mercury M-100
240 i6
3.03 trans
