Cruise-o-Matic swap for a C6 in a '67
SSerious
Post by SSerious »
I would like to swap out the cruise-o-matic for a C6 in my son's '67.
Is there a guide/how-to thread for this topic?
It would be nice to have all of the components in hand before we start this process. I dont wanna get into it and not have all of the right linkage, cooling lines, driveshaft, u-joints, etc..
Thanks!
SSerious
1971 F250 SportCustom Camper Special - 360, T18 4spd
1968 Fairlane 500 - 2 door hardtop, 390
2008 Trailblazer SS - K&N CAI, Magnaflow catback, C6 Vette transmission servos, Kooks longtube headers, Dynotuned, DashBoss
2007 Harley Nightster - D&D pipes, stage 1 intake, Screaming Eagle race tuner
Re: Cruise-o-Matic swap for a C6 in a '67
assuming the engine is the same for both transmissions. all you have to do is to remove the old mx transmission and botl in the new c6 trnsmssion. you will probably need a different lenght driveshaft. and maybe a new C6 rear transmission crossmember. the shift rod is adjustable. the bellhousing pattern will have to match the engine you have. a 352 will fit a 360/390 enigne and a 6 cyl is the same as a 302 /351w/ 351c. the 351m 400 429 and 460 are the same.
onetuford
Post by onetuford »
I've just done the swap. Mine was a car type FMX in my '67. I had a short shaft bolted yoke C-6. I changed the tailshaft and housing to the car type (slip yoke), and everything was the same. Output shaft had the same spines, same OAL. Share some more details of your situation:)
"I'm not saying, I'm just saying"
1972 Ford F250 C/S XLT 390 NP435, purchased from the son of the original owner, now named Yoda
1967 Ford f100, currently. (2nd Titled owner) Now named Captian Hook
