how many quarts tranny fluid
jjh59
Post by jjh59 »
how many quarts tranny fluid c-6 trans.,new converter
forrestbump
Re: how many quarts tranny fluid
Post by forrestbump »
Approximately 12-1/2 quarts to fill the trans and torque converter.
Larry
Hemmi06
Post by Hemmi06 »
forrestbump wrote:Approximately 12-1/2 quarts to fill the trans and torque converter.
:yt: Get a case of it!!! :D
I am feeling Deja Vu..... Hummmm
1971 F250 Camper Special
360cu with RV cam and 4v Carb
blackford72
Post by blackford72 »
WOW 12 1/2 quarts!!! I'll keep that in mind!!!
forrestbump
blackford72 wrote:WOW 12 1/2 quarts!!! I'll keep that in mind!!!
This includes enough type F trans fluid to fill the trans, torque convertor, cooler lines and trans cooler in the bottom of your radiator.
...and even more type F fluid if you're running an auxiliary transmission cooler, which I highly recommend. I plumb mine so that the fluid circulates into the cooler in the radiator first, than into the auxiliary cooler, than back to the trans. In my case, the system requires 14 quarts total.
You'll also need about another quart if you're running a deep sump trans pan, which I'm not yet, but I'm planning on that addition in the future.
Larry
blackford72
Thanks man! So 14 quarts of Type F transmisson fluid?
forrestbump
blackford72 wrote:So 14 quarts of Type F transmisson fluid?
Yes, but keep in mind that volume of type F fluid includes my very large Earl's transmission cooler. 12 to 12-1/2 quarts without my auxiliary trans cooler. More type F fluid = a cooler running transmission and a cooler running transmission = longer transmission life.
Larry
