Rearend interchange-ability
Will a 1957-1966 rearend fit a 1967-1972 truck with no modifications necessary? I know 1973 and newer are too wide. I'm talking about the half ton / f100.
- mlheppl
Re: Rearend interchange-ability
There's some good info on this subject in this thread. Aparently the late 50's to mid 60's axles were a bit narrower than the 9" for the bumps.
http://www.fordification.com/forum/view ... =4&t=57672
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
71 F250 4X4
Hmmm, found this statement, "57-67 were ones size and 68-72 were just a bit wider". Is that for the axles or the whole housing?
it seems they were talking about flange to flange. of the axle tube.
Hawkrod wrote:That is not correct, 57-67 were ones size and 68-72 were just a bit wider. This is why you have to use 68-72 axles if you use 68 and newer brakes. hawkrodmlheppl wrote:snip From 1958 to 1972, F100 9" rearends measured 57" from flange to flange. snip
