72 F100 4sp. to 73 F250 4sp.
motoski74
Post by motoski74 »
Can anyone tell me if a 4sp. from a 72 F100 with a 360 will bolt up to a 73 F250 with a 390 that also has a 4sp?
Thanks
mlheppl
Re: 72 F100 4sp. to 73 F250 4sp.
Post by mlheppl »
Are both transmissions NP435's or is one of them a T18 or T19? Either way they should bolt up just fine. I'm not sure of the driveshaft length differences needed if one of the trannys is a T18/T19 and the other is a NP435. If both transmissions are the same brand, then everything should bolt up no problem. The belhousing pattern will all be the same if both trannys were bolted up to fe engines.
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
mlheppl
Post by mlheppl »
I just noticed that this was your first post. Welcome to the site! :fr:
Mike
71 F250 4X4
ford4x4fun
Post by ford4x4fun »
welcome to the site, and yes what was already mentioned!
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
