C6 vs C4
survivorman
C6 vs C4
Post by survivorman »
I was looking up stuff on the C6, and it was said the C6 will kill 2-3 mpg vs a C4?
The C6 is a monster in terms of the abuse it can handle, and not limp home. Where as GM introduced a T475 for the heaviest of duty Ford stuck with the C6.
Sitzungstiefpunkt und fahrend langsam
Whateverman
Re: C6 vs C4
Post by Whateverman »
the reason for the fuel economy drop is that the c6 takes a fair bit more power to run than a c4 (around 20 hp more) because of the larger mass of the rotating assy
Crazymike187
Re: C6 vs C4
Post by Crazymike187 »
I am not sure if this is hear say but didn't the later model c4 come with an over drive option? If so is it possible to put one in our trucks.
Re: C6 vs C4
i dont think the c4 is made anymore. and probably hasnt been since 1980. but i could be wrong. the aod is a modified c6 i was told.
Whateverman
Re: C6 vs C4
the c4 never had an overdrive, but they did add a lockup torque convertor and called it a c5
