New Guy In Need Of Help
A place for new members to introduce themselves
lowridingf250
Post by lowridingf250 »
alright so im new here and i have a 01 crown vic that id like to use the front out of on my 67-72 1/2t f250 but i was told that the best year crown vic was a 03-07. I really hope you guys can help me out.
forrestbump
Re: New Guy In Need Of Help
Post by forrestbump »
First off... :wel:
On to the CV swap, start goin' through the project update threads. You'll find quite a few examples there.
Larry
lowridingf250
Thanx but im kinda lost right now...
forrestbump
Well than... try posting exactly what your question is in the suspension forums.
For example: I've got a '01 CV frt end, will it work? - or - "What's best yr CV for my Bump?"
Hope that gives you some ideas. Also talk it out more... What do ya mean?
lowridingf250 wrote:im kinda lost right now...
I'm actually gettin' WAY OFF TOPIC HERE... SORRY MODS, so try the other forums.
Larry
fireguywtc
Post by fireguywtc »
:wel: from Texas! :fr:
Bill
ezernut9mm
Post by ezernut9mm »
the 03 and up cross member is a bolt in deal. the earlier ones need to be cut out and grafted in.
lowridingf250
So it would still be doable with a 01
ezernut9mm
since i have no interest in this swap i haven't read all there is on it, but the way i understand it is that anything pre 03 is basically a fab in deal so there is a lot of work involved. the 03 up is the right width and is a four bold swap with some bolstering type fab.
like was said earlier, i would search crown vic swap and see what comes up. you might try searching over on the h.a.m.b. and slick 60's.
71highboy
Post by 71highboy »
:wel:
Mancar1
Post by Mancar1 »
Welcome aboard, from Northern Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
terry1167
Post by terry1167 »
Welcome from Colorado! :wel:
'72 F250,390,C6,76K Sport Custom, Camper Special "Ole Blu"
'90 F250,460,48K XLT Lariat, Supercab
'88 Lincoln Mark VII LSC, 5.0 H.O.original, was daily driver, now retired
'97 Lincoln Town Car-Cartier,73K, 4.6, fact. dual exhaust,mint/original-Last Big Towncar
'05 GMC Denali XL,6.0 Vortec-for the wife & kids
'02 Cadillac DHS,4.6 Northstar-daily driver
'73 Great Divide 22' travel trailer,restored to original
'79 Mitchell 11' "Challenger XL" cabover camper-restored to original
'88 Lance 11'3" LC 780 cabover-current project
71fordkid
Post by 71fordkid »
First off, Welcome.
Second, to use your 2001 crown vic front end, you will need to cut off your frame rails just forward of the firewall on both vehicles, and weld the two pieces together. you will have to fab core support mounts, bumper mounts, and make suure the front end sheetmetal all lines up.
With the 2003-2007 front end, There are 4 bolts going through the frame, and 8 bolts for trailing arms, and the front suspension (aluminum cross member, steering, suspension, brakes, etc...) comes out. then you will need to cut out the cross member for your I beams, line the front wheel hubs up with the center of your fenders, and drill holes intp your frame and bolt the suspension in. No need to fab bumper mounts or core support mounts.
Hope that helps you in understanding the differences in the front end swaps. :fr:
Ex Ford diesel dealership senior master tech (6 years)
Current bmw level 4 tech.
1972 Ford F100 Stepside - 302, forged TRW flat tops, performer 289 intake, edelbrock 600 cfm carb, CV IFS swap, 4.10 LSD disc 8.8 , AOD 4 speed auto. Currently 5 years in the making.
lowridingf250
Well first :fr:
but thanks i just didn't know it it was possible to still use my 01
I hope to get cutting soon but i have to wait for the ground to dry up :(
Hemmi06
Post by Hemmi06 »
Hello from California :thup: :wel:
1971 F250 Camper Special
360cu with RV cam and 4v Carb
