1968 F100 4X4.
1968 F100 4X4.
Just bought a 68 F100. 4X4 with 360 four speed. Little to no modification. Needs some tlc and various parts. I am looking for the body panel that goes under the grille and the associated hardware. Could someone point me in the right direction. Also. The 4X4 lever will not stay engaged. It pops out as soon as acceleration starts. Thank you everyone.
- old bulldog
Re: 1968 F100 4X4.
hello from nova scotia canada
- 1970FordTK
Re: 1968 F100 4X4.
Welcome from North Carolina, you might have better luck getting an answer to that question if you post it in the 4x4 section of the board.
Re: 1968 F100 4X4.
Idaho says thank you for the welcome and pointers.
- guerra
- thrush544
Re: 1968 F100 4X4.
Welcome from SE PA
Post some pics when you can!
"Courage is being scared to death, but saddling up anyway." - John Wayne
Proverbs 3: 5-6
Proverbs 3: 5-6
- Mancar1
Re: 1968 F100 4X4.
Hello from Northern Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- forrestbump
Re: 1968 F100 4X4.
Howdy and
Larry
Larry
- ta TACO
Re: 1968 F100 4X4.
Davin.
68 F-250 CS, 360 or 390?, still haven't measured the stroke, AUTO running on propane!
Re: 1968 F100 4X4.
Welcome from Mountain Home, Idaho. If you are near Boise, Try Jalopy Jungle in Nampa for parts. That is where I find mine.
Troy
- fireguywtc
Re: 1968 F100 4X4.
Bill
- FL684X4
Re: 1968 F100 4X4.
