VIN Number Location
VIN Number Location
Hi Just Got a 1967 Ford F100 and have some doubts,
Where can I find the VIN???, (the metal tag on the door was lost),
the Stamped VIN number will be something like F10YXXXXXX (an
eleven Character number)????, found a number on the
rail bust does not look like a VIN C7DAGMXXX.
Can someone help me on this.
Regards
Regards
- fireguywtc
Re: VIN Number Location
There should be a Vin# stamped into the top of the frame on the right side behind the spring perches and forward of the cab mounts.
Bill
- Mancar1
Hello from Northern Ca
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- forrestbump
fireguywtc wrote:There should be a Vin# stamped into the top of the frame on the right side behind the spring perches and forward of the cab mounts.
And
Larry
Larry
- Caseys71
Welcome from NC! As for the VIN it will be stamped on the top side of the passenger's side frame rail just like fireguy had mentioned. The other number you found was a part number (C7DAGMXXX). Once you find the VIN here's the link to decode it:http://www.fordification.com/tech/VIN67.htm Good luck with finding the VIN and see you in forums!
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
- hdpusher
Welcome from central Pa
67 Chevy II 302 sbc
67 Ford F350 Motor home
68 Ford F100 long bed (Sold
78 CJ5
03 Dodge Cummins
78 CJ5
03 Dodge Cummins
- old bulldog
hello from nova scotia canada
- randyvines
Mine has a VIN tag on the fire wall under the hood in front of the drive and Welcome from Waco
