Help/advice....PLEASE!
Ok, I have a 68 f100 longbed 4x2, factory 390, 3speed...... I pulled the motor and am putting a 390 back in but with a C6....... Im having an issue getting the trans crossmember back to its original holes and the driveshaft appears to be too long now? I was thinking it was a bolt in conversion. The 390/C6 came from a 71 f100...........any input?
"Ashes to ashes, dust to dust, if it wasn't for chevy's our tools would rust".
Re: Help/advice....PLEASE!
the two on the left are for automatic transmissions. the one on the right is for manual transmissions.FORDification wrote:Here's a chart I whipped up showing the six different transmission crossmembers used in the '67-'72 trucks, as shown in the MPC. The most-common pieces are high-lighted in grey:
[ Image ]
TAGS: transmission crossmember
Ditto, you can slot the holes in the frame or crossmember and you'll need the 3 speed driveshaft.
Jamie
Jamie
- 69rangerf100
i agree with fordman if you are using the 3spd cross member that is the issue you will need to use the c6 cross member
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
you can probably use the same crossmember. but you will have to drill holes in the frame to make it fit. and a hole in the crossmember so the transmount will bolt on in the right place.
The driveshaft will need to be cut (manual) to fit with the C6 Transmission.
You' all are great! Thanks!
