I took out my instrument cluster because i was getting a new lens and bezel. I Go to put it back in, and the speedo cable won't reach now.. It's like 2 or 3 cm short, It was threaded on when i took it off. I've gave it a good tug and no luck.
It's a square drive, and you have to mate the core to the speedometer.
It should go in if you do this.
That's not an oil leakThat's SWEATfrom all thatHORSEPOWER!!
You may have to turn the core to get it to mate to the drive gear in the tranny.
Both ends are square, and you may have pulled it out of the tranny gear when you pulled the cluster.
It's probably also a good idea to lube the cable/core while you have the cluster out.
