205 swap speedo cable question
Drednme
Post by Drednme »
I finally found a good divorced 205 to replace my bad dana 24. The only problem I have now is the obvious difference between the screw in end on my truck and the clip in end on the case, the guy had just cut off the last 6 inches of cable, but the plastic gear was stripped anyway, so really the question is where can I find a new cable and gear. For info sake the case came out of a 73 with unknown gears and is going in a 68 250 with 4.10's. Thanks for your help!
68 F-250, 4x4, 360, 4spd; BMW R1200C; 1995 jeep cherokee XJ RHD
Re: 205 swap speedo cable question
theres a guy on ebay named belair2door who sells cables. just tell him which ends and the length of the cable you need.
70_F100
Post by 70_F100 »
fordman wrote:theres a guy on ebay named belair2door who sells cables. just tell him which ends and the length of the cable you need.
:yt:
Doug Comer
Post by Doug Comer »
Averagef250 told me to just pull the ends off both speedo cable and push th one you want to use back on. I did it years ago and it worked fine. As for the gear I think any of the mail order places should have them or even your local parts house.
Doug
1967 f100 4x4
1970 f250 4x4
