here we go again...
ccryder2011
here we go again...
Post by ccryder2011 »
ok i had the c-4 in my 67 rebuilt just before x-mas...got stuck in the snow the other day and now it sounds kinda like something is not engaging properly...drives ok,no slipping but makes an awful "roar" when driving.The sound seems to increase/decrease depending on how fast the drive shaft is turning not the engine rpms...any ideas before i have to pull the tranny to bring it back to tranny shop???or could this be a rear end issue???
remember the key is to start what you finish....lol....happy cruising...
1967 f-100 sb,mine
2007 subararu wrx,son#1
2003 mitsubishi eclipse,son#2
2007 mercedes E 350,wifes
Re: here we go again...
it could be the wheel bearings.
basketcase0302
Post by basketcase0302 »
It's dangerous...I'm not saying to do it...but if it were mine?
I'd get it on jackstands with the wheels chocked with two people and listen to it. :2cents:
Might also be a dry universal joint. :pray:
ccryder2011
universal joints are new,that was my first thought...packed them with grease myself...sound is kind of a whurring,dry rear axle maybe...didnt check the wheel bearings yet, :hmm: :hw:also if iput the truck in neutral and coast the sound goes away... :hmm:
just did some quick looking around and found a 8.8 inch rear end out of a late 80's to early 90's ford truck locally on craigs list for 175 or best... will this work in my truck while i rebuild the 9 inch ???? or or not rebuild the 9 inch :hmm:
1967 f-100 sb,mine
michael69
Post by michael69 »
It more than likly is the rear. If it was spining and then getting traction and grabbing. I broke a tooth off the pinion gear and it would roar when it was under load or letting off gas. Don't know about The 8.8.Just my :2cents:
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
ford4x4fun
Post by ford4x4fun »
basketcase0302 wrote:It's dangerous...I'm not saying to do it...but if it were mine?
I have done that before.
I would look at the U-Joints, I have installed U-joints before that where bad a week later. Just poor quality of things these days. If you had U-Joint issues before I would check where the drive shaft connects to the yoke as well. I have seen those get flared out and cause the same symptoms.
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
ccryder2011
it made this noise before i put new u-joints in and didnt change at all after... :doh:
1967 f-100 sb,mine
BobbyFord
Post by BobbyFord »
Prolly axle bearing of diff. Bad axle bearings can not always be diagnosed by pulling a wheel and rotating the axle by hand. Sometimes you have to slide the axle out and spin the bearing by hand. If it is a bad axle bearing do not replace it with a Chinese bearing or you will be replacing it again soon. Bower/BCA bearing or equivalent.
ccryder2011
pulled the rear wheels and one side seems to be leaking,its not the wheel cylinders... :hmm: now how do i tell what size bearings,there is no tag on axle but looks to be origonal rear...
1967 f-100 sb,mine
mlheppl
Post by mlheppl »
There should be a number stamped on the bearing. depending upon which side it is stamped on, you may have to get the bearing off to get to where you can read the number.
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
