manual kick down
manual kick down
Can anyone tell me, on a 390 C6 Combo, should there be a manual kick down lever from the carb to the tranny along with the vacuum modulator? Seems to me that there should be, but on this truck there isn't one. If there is supposed to be one of these levers, where can you buy one? I've checked all my catalogs like LMC and they don't even acknowledge it.
- BobbyFord
Re: manual kick down
Yes, there is supposed to be a kickdown rod. I think fordman has a couple.
here is a picture of the automatic transmission kickdown lever found on stock automatic carbs. these werent put onto manual transmission carbs. maybe summit or jeggs has one to add on to a manual carb.
tags: kickdown lever rod automatic auto
- michael69
I think he is talking about the kick down rod itself that goes to trans.
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
Yes there is supposed to be a kick-down-rod. It goes from the carb down to the tranny between the firewall and the top of the motor/tranny. It's got some odd bends to get around stuff. You'll need to find a used rod. Make sure it's for a 360/390. The C6 is the only auto Ford mated to the 360/390.
he is i misunderstood it. i was probably not awake enough yet.
This is great information, thank you all for your answers! Does anyone have a rod they would like to sell? While bumps and slicks are abundant around here, they are usually found in someone who wont let go of them's back yard. They seem to be in short supply in the wrecking yards here.
- michael69
PM sent
Michael69
