Driveshaft and ignition switch question
1967F100
I'm getting a automatic C6 trany out of a 70's van. I was wondering if the driveshaft out of the van will work on my when converting from column to automatic?
Also when did vans go from ignition switch on dash to on the column?
Re: Driveshaft and ignition switch question
the driveshaft might fit. you will have to check the driveshaft lenght. the ignition switch may not fit your plug on your wiring harness. my guess is they went to column in 80 and up. i am just guessing though.
What about the power steering gearbox and column if its equipped with it?
the vans steering box and steering linkage is in front of the crossmember.it wotn interchange with our trucks. the steerign column might. if you change the firewall seal to a truck firewall seal. other than arm rests that is almost all that can be used from a van. major parts anyway.
Can you still get a replacement truck firewall seal? What about the 67-69 truck steering wheel fitting the van column?
the column is the same size around as ours is. unless you get up into the 78/79columns thne they get larger around i think. yes they do sell column seal replacements.
- Hawkrod
Van columns are much longer than truck columns. 1980 is the year they went to locking columns. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- Hawkrod
Almost 7 inches longer, it is not doable as a bolt in. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- ForingaMex
I had to shorten the van column quite a bit to fit into my bump. I don't remember exactly how much though.Hawkrod wrote:Van columns are much longer than truck columns. 1980 is the year they went to locking columns. Hawkrod
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
here is a picture of a earlier van steering box and firewall.
