T5 bench seat clearance
tybob81
Post by tybob81 »
I'm wanting to tell a new guy at work he won't have any stock bench seat clearance with his 79 f150 if he puts a T5 in to replace the T18 he has now behind his inline 6. He just had the interior all redone so bucket seat or modifiying the bench isn't an option. He drives the truck daily with little to no towing and wants better fuel mileage and reduced engine wear since he just rebuilt the 300. I think there is a certain style T5 that fits better than the other but I'm not 100% for sure.
71highboy
Re: T5 bench seat clearance
Post by 71highboy »
he might have to tweek his shifter :2cents:
averagef250
Post by averagef250 »
M5R2
ta TACO
Post by ta TACO »
Sorry to butt in here, but ya'll lost me on the T5, T18 and M5R2 :? .
68 F-250 CS, 360 or 390?, still haven't measured the stroke, AUTO running on propane!
Mancar1
Post by Mancar1 »
They are talking Transmissions lingo.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
ta TACO
Post by ta TACO »
Roger, thanks.
beaumont_68
Post by beaumont_68 »
Im going to be doing a T18 to M5R2 swap very soon on the 68' I recovered everything from a 88'
68 F100 300 Daily Driver (The Hillbilly Hot-Rod)
70 F250 360 parts truck
MadMaxetc
Post by MadMaxetc »
Here is mine.
Image Image Image
Image Image Image
The seat is all the way back.
Dan
FORD Girl
Photobucket Pictures
