SPECIAL ORDER REAR END
Racer Z
Post by Racer Z »
I am looking at an eBay add for a 69 F100 w/overdrive. He says it has, "SPECIAL ORDER REAREND" with a 390 and 3-speed. I have sent the seller a question asking about the "SPECIAL ORDER REAREND". Are any of you familiar with this? I am under the impression that only huge trucks like F600 and up have a two-speed read end and that it probably isn't feasible to install one in my F250.
I am assuming that the overdrive is the "special rear end", but it's possible that they are two separate items.
Link to the eBay add:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 500wt_1022
Thanks for any input on this guys.
Re: SPECIAL ORDER REAR END
3spd with over drive means its a T89 overdrive transmission. he is probably refferring to the whoel truck was a special order truck and got a different rearend than was suppose to be used in that truck. i saw nothing that said 2 speed rear end in it.
Racer Z
Post by Racer Z »
fordman, you are probably correct. There is a much greater chance the overdrive is a part of the tranny and not a part of the rear end. I guess it was just wishful thinking on my part. I'll post the sellers response if I get one.
71highboy
Post by 71highboy »
my wife had a special order rearend and it was good for the first 22 years of our marriage after that it started to hang a bit. :lol:
Doug Comer
Post by Doug Comer »
At least it didn't start leaking :doh:
1967 f100 4x4
1970 f250 4x4
DragRag
Post by DragRag »
If by chance it is on the rear end, it will be Hone-O-Drive. That is a very rare overdrive that could be bought, and bolts directly to a 9" rear end. A 8" rear end model was available also, and a divorced unit to. The models for those were 100 for an 8", 200 for a 9" rear, and 300 for the unit that is divorced that bolts in the tunnel of what ever car they are going on. A popular choice for RVer's as well as Hot Roders. Kind of pricey they are.
Racer Z
Post by Racer Z »
Based on your description, the Hone-O-Drive won't fit a Dana 60. Not giving up my floating axle. Sounds good for a 1/2 ton truck though.
71highboy
Post by 71highboy »
Doug Comer wrote:At least it didn't start leaking :doh:
lmao :lol:
Mancar1
Post by Mancar1 »
When you hit a certain age in life, that stops being a joke. :lol:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Bullitt390
Post by Bullitt390 »
It sure sounds like his description calls for a special rear axle. Of course he doesn't show any pictures of it or go to further explain what overdrive it has.
Josh
mybros71
Post by mybros71 »
Looks like the seller responded and says its a Dana 60, LS, 3.54 gears.
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
71highboy
Post by 71highboy »
very true :cry:
limited slip that would explain why he says that. did someone say the d60 only came in 3.73 and 4.11 unless it was limited slip?
Racer Z
Post by Racer Z »
The seller sent me an answer to my question about the rear-end.
"IT HAS A DANA 60 LIMITED SLIP 3.54 GEAR RATIO REAREND"
Not the two-speed I was hoping for, but definitely a plus for who ever buys the truck.
