my bump got bumped today
71highboy
Post by 71highboy »
so after taking my grandson sledding we were on are way to walmart and stopped in traffic and wham got hit in the rear my head hit the back window and thankfully my grandson is only 6 years old so his head only hit the back of the seat.the girl that hit my bump is only 16 years old and her bonneville got totaled but thankfully everyone in her car was ok.i am lucky that i have a 1/4 in tubular rear bumper the only thing body wise is the brackets got torn up.but when the police wanted me to dislodge my truck the transfer case was in the neutral position and now it pops out of gear so any suggestions on why that would happen after a rear end accident?
Re: my bump got bumped today
it happened because of the force from behind hitting a object that probably didnt want to move much. but it found its way to the weakest point it could in your truck. i would first look at the linkage and or case itself. as well as the trans to see if it was cracked or broken. if nothing is hurt on the outside it has to be inside of the tranfer case or the transmission.
1971ford
Post by 1971ford »
Obviously something bent, broke, or shifted, just a matter of what.
Inspect the motor mounts, tranny mount, and definitely the t-case mounts. I'm sure your t-case bushings are totally wasted if you've never replaced them before.
when you say it jumps out of gear are you still talking about the t-case or the np435.
If you put it in 2hi does it stay in 2hi or does it jump to neutral?
If it is jumping to neutral then the linkage must be right on the border of neutral/2hi. which, if im thinking correctly (1 in the morning) would mean the t-case moved forward, but i'd think it would move back, because of inertia, like your head hitting the window.
-Ryan
mlheppl
Post by mlheppl »
Sorry to hear about your misfortune. I would look the transfer case mounts over and make sure that the transfer case wasn't shifted. If it's in the right place, then likely something is broke in the transfer case, but I would think that the transfer case likely shifted. Let us know what you find.
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
71highboy
Post by 71highboy »
ok thank you everyone.itsgoing to have to go to a shop because i dont have a garage and i dont want to crawl around in the snow and ice.thanks again :fr:
71highboy
Post by 71highboy »
and now 3 days later ?i have whiplash.wth :cry:
mlheppl
Post by mlheppl »
That sux. I don't know how long it takes for whiplash to go away, but I hope it's a speedy recovery for you.
Mike
71 F250 4X4
mrsnicks
Post by mrsnicks »
First I'm glad everyone is okay. 2nd you ALWAYS feel worse 24-78 hours after the accident. Can't help on the popping out of gear problem but I hope it's a simple fix. Good luck dealing with the insurance companies.. major pain in the ass as far as I'm concerned.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
my hand is barley healed up from my wrecked over thanksgiving weekend. it will take some time for you to heal up. you may want to go to the doctor if you can. i didnt and wished i did .
71highboy
Post by 71highboy »
yeah i went to the doctor and they sent me to a chiropractor and did xrays and my discs in my neck are way off.the doc said it sometimes takes days for the pain to start.he says 5or 6 months for recovery.time to call a lawyer. :cry:
well time to let the insurance company know so they can start paying the bills. if they dont then its time for a lawyer.
mlheppl
Post by mlheppl »
Hopefully the girl that hit you has insurance.
Mike
71 F250 4X4
71highboy
Post by 71highboy »
yeah the girl has insurance and i did let them know about the medical so all should be ok.I HOPE :cry:
71highboy
Post by 71highboy »
mlheppl wrote:That sux. I don't know how long it takes for whiplash to go away, but I hope it's a speedy recovery for you.
thank you
